Select items to delete from cache dialog box
The Select Items To Delete from Cache dialog box enables you to delete point cloud files that are stored in the cache.
- Cache used
- Available
- Dataset
- Size
- OK
- Cancel
Cache used
Specifies the total amount of used cache.
Available
Specifies the total amount of available cache. The available cache is controlled by the POINTCLOUDCACHESIZE system variable.
Dataset
Displays a list of cached point cloud files including their names and locations. You can select point cloud files from the list to delete them from the cache.
Size
Displays the amount of cache used for each point cloud file.
OK
Displays the Confirm deleting selected cache items dialog box where you can review the list of point clouds to be deleted.
Cancel
Closes the dialog box without deleting point cloud files from the cache.
