MODEL command
Switches to the Model tab.
Switches the active tab from the current layout tab to the Model tab.
You can also perform this action by clicking the Model tab on the Status bar, using the Layout Manager dialog box or using the LAYOUT command.
For more information on working with layout tabs, see the Layouts and Model space and paper space articles.
Note: The LAYOUTREGENCTL system variable controls how the display of the Model and layout tabs is updated. You can use this system variable to improve display performance. See the LAYOUTREGENCTL system variable article for more information.
