Administration
Overview
The Administration tool allows project administrators to set up and manage the project environment. Only project administrators can see and use this tool.
The Administration tool is divided into different categories:
  • Project settings
    Enter or edit the basic information of a project, and change project settings.
  • Project setup
    View, add or edit the project structure and access rights to roles per folder.
    Synchronize to LetsBuild.
  • Users
    View, invite, or delete users and assign roles to users.
  • Roles
    View, import, copy, edit, or delete roles.
  • Relations
    Manage relations.
  • Administrators
    Specify to which sections an administrator has access.
  • App access
    Enable or disable access by third-party apps to a project, and set permissions for roles.
  • Form entries access
    View or edit the access rights to forms.
  • Audit report
    Search for all activities in a project.
  • Recycle bin
    Restore documents and folders from the recycle bin to your project, or permanently delete the items.
