Bricsys 24/7 Viewer
The Bricsys 24/7 Viewer allows you to view more than 70 file formats without additional software.
The supported file formats are:
Format File extension
Text asm, bat, c, css, cpp, cxx, gene, h, hxx, idh, idl, inl, java, log, lsp, rss, sql, tpl, text, txt, xml
Image bmp, gif, jpg, jpeg, pcx, pgm, pict, png, ppm, tga, tif, tiff, xbm, xpm, xwd, ai , psd
Office doc, docx, dot, dotx, odf, odg, odp, ods, odt, potx, pps, ppsx, ppt, pptx, rtf, xls, xlsb, xlsx, xlt, xltx, vsd
CAD dwg, dwf, dwfx, dxf, dgn, plt, hp, hpg, hpg, ifc*
Other htm, html, pdf, ps, zip
(*) Only IFC2×3 (coordination view 2.0) is supported.
Open the Bricsys 24/7 Viewer
  1. Make sure that a document details window is selected.
  2. Click Open in viewer.
    The Bricsys 24/7 Viewer opens.
Navigation in Bricsys 24/7 Viewer
The Bricsys 24/7 Viewer contains:
  1. Menu bar
    • Thumbnails: show or hide thumbnails
    • Add annotation
    • Download
    • Print to PDF
    • View, Zoom and Rotation icons
    • Annotations icon: show or hide annotations
      A counter indicates the number of annotations in a document.
  2. Thumbnail pane
    A thumbnail is displayed for each available page. Click on a thumbnail to open the corresponding page.
  3. Current view of the document
    The selected thumbnail is highlighted and the viewed area is indicated.
  4. Status bar
    The available layouts or sheets of a document are displayed via tabs.
  5. Annotation pane
