Create a task You can create a task: Click Tasks in the toolbar. Click New task. The Create a new task window appears. Enter a name for the new task. If applicable, edit the assignee. If applicable, add a description and a due date. If applicable, attach documents from your project in Bricsys 24/7 and/or from your local device. Click Create. A pop up window informs you that the task is created. The counter in the toolbar displays the number of open tasks. The assignee receives an email with a direct link to the task.
