Edit folder access
You can toggle between the access rights:
  1. Click Administration in the toolbar.
  2. Click Project setup.
  3. Set the permissions by Type and Role.
  4. Click on the different access type icons to set a specific access type.
    As an alternative, use the arrow icons to toggle between the access rights.
    Icon Description
    View
    Print
    Download
    Add
    Add revision
    Annotate
    Edit
    Delete
    Attach workflow
    Add subfolder
    Share
    Attach form
    Icon Access type Description
    no access
    access own rights to objects created or uploaded by the user in the specific folder
    access all rights to all objects in the specific folder
  5. Click Save changes.
    A pop up window informs you that the folder access changes are saved.
Note: Depending on the type of folder, not all access types might be available.
