Recycle bin
All documents and folders that are deleted in Bricsys 24/7 are moved to the recycle bin first (soft delete). In the recycle bin, you can still restore items, or delete the items permanently (hard delete).
Only administrators have access to the recycle bin.
Important: In order to delete items in the recycle bin, the option Lock recycle bin can not be enabled.
Restore a document or folder
You can restore an item:
  1. Click Administration in the toolbar.
  2. Click Recycle bin .
  3. Select a document or folder in the content pane.
  4. Click Restore item.
    The Restore item window appears.
  5. Click Restore to restore the item.
The item is restored to the original folder or project.
Delete an item
You can delete an item:
  3. Select an item in the content pane.
  4. Click Delete forever.
    The Delete forever window appears.
  5. Click Delete to delete the item.
The item is permanently deleted.
Delete all items
You can delete all items at once:
  3. Click Empty bin.
    The Empty bin window appears.
  4. Click Confirm to empty the recycle bin.
The items are permanently deleted.
