Add a binder
You can add a binder:
  1. Click Administration in the toolbar.
  2. Click Project setup.
  3. Click Add binder in the content pane to add a binder.
    The Add binder window appears.
  4. Enter a name for the new folder.
  5. If applicable, enable Show only documents with status.
    Select the applicable statuses.
  6. Choose the default access rights for all roles.
  7. Click Add.
A pop up window informs you that the binder is successfully added.
