Add a document to a binder
You can add a document to one or more binder folders:
  1. Click Files in the toolbar.
  2. Select the applicable folder.
  3. Select the document(s) you want to add to a binder folder.
  4. Click the ellipsis button at the top of the content pane.
    A context menu pops up.
  5. Click Add to binder.
    The Add to binder window appears.
  6. Select the binder(s) you want to add the document to.
    Note: If available, you can select a sub-binder by clicking the arrow (1) next to the folder name.
  7. Optional: Click Select revision to choose a specific revision to add it in the binder.
    Note: If you do not select a revision, you will always see the latest version in the binder.
  8. Click Add.
    A pop up window informs you that the documents are added to the binder(s).
