Add a folder You can add a folder: Click Administration in the toolbar. Click Project setup. Click Add folder in the content pane to add a folder, The Add folder window appears. Enter a name for the new folder. Choose the default access rights for all roles. Click Add. A pop up window informs you that the folder is successfully added.
