You can add a hyperlink to a (sub)folder:
Click Files
in the toolbar.
Select the applicable (sub)folder in the tool menu.
Click the ellipsis button
at the top of the content pane.
A context menu pops up.
Click Add hyperlink.
The New hyperlink window appears.
- Enter a name.
Add a link to an external website or an internal document.
If applicable, enter a description.
Click Add.
A pop up window informs you that the hyperlink is successfully added.
