Add a subfolder
You can add a subfolder:
  1. Click Administration in the toolbar.
  2. Click Project setup.
  3. Select the applicable folder in the content pane.
  4. Click the ellipsis button at the top of the content pane.
    A context menu pops up.
  5. Click Add folder.
    The Add new folder to window appears.
  6. Enter a name for the new folder.
  7. If applicable, enter a description.
  8. Enable or disable Copy access rights from parent folder.
  9. Enable or disable Copy metadata from parent folder.
  10. Enable or disable Copy automatic workflows from parent folder.
  11. Click Add.
Pop up windows inform you that the folder is successfully added, and that the enabled items are copied.
