Create a workflow
You can create a workflow:
Click Workflows
in the toolbar.
- Select the applicable workflow folder in the tool menu.
- Click Add workflow.
The Add workflow window appears.
Enter a name.
Important: Every workflow name in a project must be unique.
- Define the coordinator role.
- If applicable, enter a description.
Click Add to save the workflow.
The Bricsys 24/7 Workflow Viewer opens.
- Follow the instructions in Design a workflow to create a workflow.
