Add a form entry to a form
You can add an entry to a form:
  1. Click Forms in the toolbar.
  2. Select the applicable form folder in the tool menu.
  3. Select the applicable form in the content pane.
  4. Click Add Entry.
    The applicable form field appears.
  5. Adjust the setting(s) of the form field.
  6. Click Submit
    Pop up windows inform you that the entry is added and the form entry is submitted.
  7. Click Add another entry, or click the X icon to return to the selected form folder.
