Enter the name of a project member, or enter an email list in the To field of a communication window.
Email lists are set up by the project administrator.
If applicable, edit the email list:
Select the email list.
Untick the checkbox next to the project member.
Important: You can only add recipients who are allowed to view the applicable item. The project administrator needs to give you access to communicate with other project members.
