Add a workflow to a binder
You can add a workflow to one or more binders:
  1. Click Workflows in the toolbar.
  2. Select a workflow folder in the tool menu.
  3. Select a workflow in the content pane.
  4. Click the ellipsis button at the top of the content pane.
    A context menu pops up.
  5. Click Add to binder.
    The Add to binder window appears.
  6. Select the binder(s) you want to add the workflow to.
    Note: If available, you can select a sub-binder by clicking the arrow (1) next to the folder name.
  7. Click Add.
    A pop up window informs you that the items are added to the binder(s).
