You can attach a workflow to a folder:
Click Administration
in the toolbar.
Click Project setup.
Select the applicable folder in the content pane.
Click the ellipsis button
at the top of the content pane.
A context menu pops up.
Click Attach workflow.
The Attach workflow window appears.
Choose a workflow.
Select a coordinator.
If applicable, enable Apply this workflow to all subfolders of this folder.
If applicable, enable Also start this workflow when a revision is uploaded.
If applicable, enable Cancel previous workflow when adding a revision.
Click Attach.
A pop up window informs you that the workflow is successfully attached to the folder.
