BIM files
Centralize, store, and manage your BIM
Bricsys 24/7 handles projects with vast amounts of BIM data and all associated documents. 24/7’s model server manages all of the information that comprises a construction project. You can query, merge and filter your view of the BIM model depending on your individual needs.
![](https://static.bricsys.com/help/images/247/en_US/BIM_02.jpg)
![](https://static.bricsys.com/help/images/247/en_US/BIM_03.jpg)
Upload from BricsCAD with Full XREF management
When serving a BricsCAD BIM model using external references, Bricsys 24/7 recognizes and automatically manages the links between the files. A direct connection to Bricsys 24/7 is available in BricsCAD and BricsCAD BIM.
![](https://static.bricsys.com/help/images/247/en_US/BIM_04.jpg)
View BIM data
- Click Files
in the toolbar.
- Select the applicable BIM folder or file.
- Click
to open the DATA/ACTIVITY/DETAILS pane.
You will see a list of BIM data in the DATA tab. Select one to view the details.
3D Viewer: View and explore your BIM
To view the BIM data in 3D, select the data in the DATA tab and click View in 3D model.
![](https://static.bricsys.com/help/images/247/en_US/BIM_05.jpg)
![](https://static.bricsys.com/help/images/247/en_US/BIM_06.jpg)
Industry Foundation Classes (IFC)
Bricsys 24/7 provides full IFC support. IFC allows the accurate transfer of BIM data across multiple applications programs, and between disciplines. IFC2×3 (coordination view 2.0) is supported.
- Upload IFC files
- Click Files
in the toolbar.
- Select a BIM folder.
- Click Upload.
A modal window appears.
- Select the IFC file(s) you want to upload.
The Uploading window appears.
- Set the status.
- Optional: type a description.
- Click Upload.
A pop up window informs you that the IFC file is successfully added.
- Click Files
- View IFC files
- Click Files
in the toolbar.
- Select a BIM folder that contains IFC files.Note: If an IFC file is viewable, the file type icon (
) is displayed.
- Click the IFC file.
The file details window opens.
- In the Info tab click Open in viewer to open the file in the Bricsys 24/7 Viewer.Note: If an IFC file is not viewable, the Open in viewer button is grayed out and the information that the file can not be previewed is displayed.
- Click Files
