Cancel a workflow
If you cancel a workflow, the workflow is put on hold. It is possible to activate the workflow again if necessary.
You can cancel one or more workflows:
Important: You need the appropriate permission to access the document.
As an alternative, select Workflow name to cancel all workflows.
