Change the folders order
You can change the order of the folders.
  1. Click Administration in the toolbar.
  2. Click Project setup.
  3. Select the applicable folder(s) in the content pane.
  4. Hover over and drag and drop the folder to the desired position.
    Note: You can only change the folder order if you are the project owner. If not, contact the project owner to obtain this right.
A message appears that the folder has been moved.
