You can change the order of the folders.
- Click Administration in the toolbar.
- Click Project setup.
- Select the applicable folder(s) in the content pane.
- Hover over and drag and drop the folder to the desired position.
Note: You can only change the folder order if you are the project owner. If not, contact the project owner to obtain this right.
A message appears that the folder has been moved.
