Consult a workflow
You can consult a workflow:
  1. Click Workflows in the toolbar.
  2. Select a workflow folder in the tool menu.
  3. Select the applicable workflow status from the drop-down menu at the top of the content pane:
    • All statuses
    • New
    • Released
    • Obsolete
  4. Select a workflow in the content pane.
  5. Click Open viewer.
    The Bricsys 24/7 Workflow Viewer opens.
  6. Check the workflow.
  7. Close the Bricsys 24/7 Workflow Viewer.
