Consult a workflow
You can consult a workflow:
- Click Workflows in the toolbar.
- Select a workflow folder in the tool menu.
- Click the filter button next to the Status column to select the applicable workflow status from the drop-down menu. The available statuses are:
- (Select all)
- New
- Released
- Obsolete
Note: The default statuses are set to New and Released.- To view obsolete workflows, select the Obsolete status.
- To view all workflows, select the (Select all) status.
- Select a workflow in the content pane.
- Click Open viewer.
The Bricsys 24/7 Workflow Viewer opens.
- Check the workflow.
- Close the Bricsys 24/7 Workflow Viewer.
