Consult document details
- Click a document name in the content pane to open the document details dialog. This dialog contains all the information of a document.
- To expand the menu, click Expand menu at the bottom left corner of the window.
The vertical menu contains different options:
- Info
- Contains the same information as the DETAILS tab in the Files app, as well as the locations where the document is displayed: folder and binders, and whether the document has been shared publicly.Note: The folder locations of a file are displayed in the Location section and are separated across different projects. You can click a project folder to open it in the Files app.
Click the preview to view the document in our online viewer.
- Communication
- View all the communication concerning this document, easily filter on the type of communication and revision.
The users who the notification has gone to as a Cc or a Bcc are shown as default in the notification details. Bcc is only seen by the sender and the (unique) Bcc recipient(s).
- Metadata
- Allows you to view all the attached metadata for all revisions or for a specific one.
- Workflows
- Allows you to view the workflows that are active, finished or cancelled. If a workflow has active tasks and you are assigned to a task, you can respond to the task from here.
- Attachments
- Allows you to view all the items that are linked to this document and the items the document is part of.
- Versions
- The process from draft to delivered document is saved by versions. Each version has a status and description to indicate its process.
This tab contains all the versions a document has. There is no limit on the number of versions. The administrator decides how revisions are displayed:
- 0,1,2,3,4...
- 1,2,3,4,5...
- a,b,c,d,e...
- A,B,C,D,E...
- -,a,b,c,d...
- -,A,B,C,D…
Versions can have a major and minor version. This is decided by the administrator of the project. This way a revision could be "A.1" instead of just "1".
Hover over a version and click the three dots from right to:
- Download version
- Copy revision
- Add to binder
- Delete versionNote: A revision can be deleted only if you have the Delete access on the document from , and the project administrator allowed the deletion of revisions.
- Print to PDF
- History
- Allows you to take a look at the history of this document. Here you can find information about the action taken by a user, the date when the action was performed, its name (for example, Revise, Edit, Add) and the revision number.
- Select an option in the vertical menu to perform additional actions.
The available actions correspond to the selected option.
Examples:- Share a revision or a document via the icon.
Choose between Revision and Document.
Click the button next to the URL to copy the URL to the clipboard.
- Remove metadata via the Delete meta data button.
The Delete meta data window appears.
Click Delete to permanently delete the metadata.
- Cancel a workflow via the ellipsis button and Cancel workflow button.
- Skip a workflow activity via the Skip activity button for a workflow with an automated task.
- Download attachments via the icon.
- Remove attachments via the X icon.
- Delete a revision via the vertical ellipsis button and Delete version button.
