Consult the folders forms overview
You can consult the folders forms overview:
- Click Administration in the toolbar.
- Click Project setup.
Click the ellipsis button at the top of the content pane.
A context menu appears.
Click Folders forms overview.
The Folders forms overview window appears.Tip:
- Click on a column header to sort the items in that column.
- Filter the list with one of the filter buttons.
- Click on a form name to open a preview of the form.
- The number of forms is displayed.
If you want to edit an attached form:
- Hover over a form.
- Click the Edit icon.
The Edit metadata: Attached form name window appears.
- Select and/or edit your preferred settings.
- Click Confirm.
If you want to remove an attached form:
- Click the X icon.
The Detach form window appears.
- Click Detach to confirm.
A pop up window informs you that the link is removed.
- Click Close to close the window.
