Consult the folders workflows overview
You can consult the folders workflows overview:
- Click Administration in the toolbar.
- Click Project setup.
Click the ellipsis button at the top of the content pane.
A context menu appears.
Click Folders workflows overview.
The Folders workflows overview window appears.Tip:
- Click on a column header to sort the items in that column.
- Filter the list with one of the filter buttons.
- Click on a workflow name to open the workflow in the Bricsys 24/7 Workflow Viewer.
- The number of workflows is displayed.
If you want to edit an attached workflow:
- Hover over a workflow.
- Click the Edit icon.
The Edit attached workflow to folder window appears.
- Select your preferred settings.
- Click Save.
A pop up window informs you that the workflow is successfully attached to the folder.
If you want to remove an attached workflow:
- Click the X icon.
The Detach workflow window appears.
- If applicable, enable Detach this workflow from all subfolders of this folder.
- Click Detach to confirm.
A pop up window informs you that the workflow is successfully detached from the folder.
- Click Close to close the window.
