Consult the folders workflows overview
You can consult the folders workflows overview:
  1. Click Administration in the toolbar.
  2. Click Project setup.
  3. Click the ellipsis button at the top of the content pane.
    A context menu appears.
  4. Click Folders workflows overview.
    The Folders workflows overview window appears.
    Tip:
    • Click on a column header to sort the items in that column.
    • Filter the list with one of the filter buttons.
    • Click on a workflow name to open the workflow in the Bricsys 24/7 Workflow Viewer.
    • The number of workflows is displayed.
  5. If you want to edit an attached workflow:
    1. Hover over a workflow.
    2. Click the Edit icon.
      The Edit attached workflow to folder window appears.
    3. Select your preferred settings.
    4. Click Save.
      A pop up window informs you that the workflow is successfully attached to the folder.
  6. If you want to remove an attached workflow:
    2. Click the X icon.
      The Detach workflow window appears.
    3. If applicable, enable Detach this workflow from all subfolders of this folder.
    4. Click Detach to confirm.
      A pop up window informs you that the workflow is successfully detached from the folder.
  7. Click Close to close the window.
