Copy a document
You can copy one or more documents to another folder:
- Click Files in the toolbar.
- Select the applicable folder.
- Select the document(s) you want to copy.
- Click the ellipsis button at the top of the content pane.
A context menu pops up.
- Click Copy.
The Copy window appears.
- If applicable, edit the document name, and update the status.
- Select the target project and folder.
- If applicable, enable Add as revision of.
- If applicable, tick Copy with notes and annotations.
- Click Copy.Note: When copying document(s) to a folder that has a form attached to it configured to Rename uploaded documents based on the fields' content, the resulting file name is predicted at the bottom of the Fill in metadata window.
A pop up window informs you that the documents are copied.
If applicable, click Send notification in the pop up window to inform users by email.
