You can copy one or more folders:
Click Administration
in the toolbar.
Click Project setup.
Select the applicable folder(s) in the content pane.
If applicable, click the ellipsis button
at the top of the content pane.
- Click Copy.
The Copy folder window appears.
Select the target folder.
If applicable, enable Include subfolders.
Click Copy.
A pop up window informs you that the folder is copied.
