Copy a workflow
You can copy a workflow:
Click Workflows
in the toolbar.
- Select a workflow folder in the tool menu.
- Select a workflow in the content pane.
Click the ellipsis button
at the top of the content pane.
A context menu pops up. -
Click Copy.
The Copy window appears.
Select the workflow folder where you want to copy the workflow to.
Tip: If applicable, you can copy the folder to a different project.
- If applicable, edit the file name, define the role, and enter a description.
Click Copy.
A pop up window informs you that the workflow is successfully copied.
