Create a task
You can create a task:
  1. Click Tasks in the toolbar.
  2. Click New task.
    The Create new task window appears.
  3. Enter a name for the new task.
  4. If applicable, edit the assignee.
  5. If applicable, add a description and a due date.
  6. If applicable, attach documents from your project in Bricsys 24/7 and/or from your local device.
  7. Click Create.
  • A pop up window informs you that the task is created.
  • The counter in the toolbar displays the number of open tasks.
  • The assignee receives an email with a direct link to the task.
