Create the folder structure
You can create the folder structure for the project.
- Select the project.
- Click Administration
in the toolbar.
- Click Project setup in the tool menu.
All folders and subfolders are displayed per app.
- Choose between Add folder, Add binder and Add BIM.
Add a folder
- Click Add folder to add a folder.
The Add subfolder window appears.
- Enter a folder name.
- Click on the different access type icons, or use the arrow icons
to toggle between the access rights for all roles.
- Click Add.
A pop up window informs you that the folder is successfully added. The new folder appears in the content pane.
Add a binder
- Click Add binder to add a binder.
The Add binder window appears.
- Enter a name for the binder.
- If applicable, enable Show only documents with status, and select the applicable statuses.Note: The available document statuses correspond to the project settings.
- Click Add.
A pop up window informs you that the binder is successfully added. The new binder appears in the content pane.
Add BIM
- Click Add folder to add a BIM folder.
The Add BIM subfolder window appears.
- Click Add.
A pop up window informs you that the BIM folder is successfully added. The new folder appears in the content pane.
