Delete a folder
You can delete one or more folders:
  1. Click Administration in the toolbar.
  2. Click Project setup.
  3. Select the applicable folder(s) in the content pane.
  4. If applicable, click the ellipsis button at the top of the content pane.
  5. Click Delete.
    A warning message appears to ask if you want to delete the folder(s).
  6. Click Delete.
    The folder(s) is/are deleted.
