Delete a project
Deleting a project:
  • Retains all project data and settings.
  • Prevents users from entering the project.
You can delete a project:
  1. Log into Bricsys 24/7 on the login page.
    All projects are displayed.
  2. Click My projects.
    Result: My projects are displayed.
  3. Select project status ACTIVE from the drop-down menu below the project bar.
  4. Select a project in the content pane.
  5. Click the ellipsis button at the top of the content pane.
    A context menu pops up.
  6. Click Delete project.
    The Delete project(s) window appears.
  7. Click Confirm.
A pop up window informs you that the project is successfully deleted.
Note: You can still restore a deleted project.
