Delete a workflow
If you delete a workflow, the workflow is moved to the recycle bin.
You can delete a workflow:
  1. Click Workflows in the toolbar.
  2. Select a workflow folder in the tool menu.
  3. Select a workflow in the content pane.
  4. Click the ellipsis button at the top of the content pane.
    A context menu pops up.
  5. Click Delete.
    The Delete workflows window appears.
  6. Click Delete to delete this workflow.
    A pop up window informs you that the workflow is successfully deleted.
Note: You need the appropriate permission to be able to delete a workflow.
