Download and lock a document
You can download and lock a document:
  1. Click Files in the toolbar.
  2. Select the folder you want to download from.
  3. Select the document you want to download and lock.
  4. Click the ellipsis button at the top of the content pane.
    A context menu pops up.
  5. Click Download and lock .
The document is saved to your download folder and is displayed as locked in the content pane.
Example: .
The document can not be edited or moved by other project members.
