Drag and drop a document
You can drag and drop one or more documents:
  1. Click Files in the toolbar.
  2. Select the folder you want to upload to.
  3. Drag and drop the document(s) from your local device to the content pane.
    Note: You can also first click on the file to open it and then drag and drop a new version of the file from File Explorer.
    The Uploading window appears.
  4. If applicable, add a status and a description per document.
    Note: The available document statuses are: draft, proposal, in preparation, revised, and approved with remarks.
    Note: If you first open the document and drag a file with the same extension from File Explorer, you can tick the option Rename to: to rename the document.
    Note: If the file name already exists in the folder you want to drag and drop a file to, you can:
    • Tick the upload this document as a copy checkbox to upload the document as a separate file. If applicable, enter the required options.
    • Tick the Replace last revision checkbox to upload the document as a new revision.
  5. Click Upload.
    A pop up window shows the upload progress and informs you that the documents are successfully uploaded.
Tip: If you want to upload a lot of documents simultaneously, you can use the Bricsys 24/7 Transfer Tool.
