Edit a contact
You can edit a contact:
  1. Click Address Book in the toolbar.
  2. Select an address book in the tool menu.
  3. Select a contact in the content pane.
  4. Click Edit contact.
    The Edit contact window appears.
  5. Edit the contact details.
  6. Click Edit.
A pop up window informs you that the contact is successfully edited.
If applicable, click Send notification in the pop up window to inform users by email.
