Edit a folder You can edit a folder: Click Administration in the toolbar. Click Project setup. Select the applicable folder in the content pane. Click Edit. The Edit folder window appears. Rename the folder. If applicable, edit the description. Click Edit. A pop up window informs you that the folder is edited.
