Edit a user Click Administration in the toolbar. Click Users. Select a user. Click Edit user. The Edit user window appears. Edit the details you want to update. Note: First name, Last name, Email address, and Role are required fields. The Email address field cannot be edited. Click Save changes. A pop up window informs you that the contact is successfully edited.
