Edit a workflow
You can edit the activities and transitions of a workflow:
  1. Click Workflows in the toolbar.
  2. Select a workflow folder in the tool menu.
  3. Select a workflow in the content pane.
  4. Click Edit.
    The Edit window appears.
  5. Click on the magnifying glass in the preview pane.
    The Bricsys 24/7 Workflow Viewer opens.
  6. Edit the workflow.
  7. Click Save .
    A pop up window informs you that the workflow is edited.
  8. Close the Bricsys 24/7 Workflow Viewer.
Note: As an alternative, you can click on the file name of a workflow in the content pane to open the Bricsys 24/7 Workflow Viewer and edit the workflow.
