You can edit document details:
Click Files
in the toolbar.
Select the applicable folder.
Select the document you want to edit.
Click the ellipsis button
at the top of the content pane.
A context menu pops up.
Click Edit.
The Edit document details window appears.
Edit the document details:
- Name
- Status
Note: The available document statuses correspond to the project settings.
- Description
Note: If applicable, the Project Owner and Contractor details are displayed.
Click Edit.
A pop up window informs you that the document is successfully updated.If applicable, click Send notification in the pop up window to inform users by email.
