Edit folder access
You can toggle between the access rights:
- Click Administration
in the toolbar.
- Click Project setup.
- Set the permissions by Type and Role.
Click on the different access type icons to set a specific access type.
As an alternative, use the arrow icons
to toggle between the access rights.
Icon Description View Print Download Add Add revision Annotate Edit Delete Attach workflow Add subfolder Share Attach form Icon Access type Description no access access own rights to objects created or uploaded by the user in the specific folder access all rights to all objects in the specific folder - Click Save changes.
A pop up window informs you that the folder access changes are saved.
Note: Depending on the type of folder, not all access types might be available.
