Edit form access
You can toggle between the access rights:
  1. Click Administration in the toolbar.
  2. Click Form entries access in the tool menu.
  3. Select the applicable Role next to Set permissions for.
  4. Click on the arrow icon next to the applicable form in the content pane.
    All relevant form fields appear.
  5. Click on the different access type icons to set a specific access type.
    Full access:
    No access:
    Tip: As an alternative, use the arrow icons to toggle between the access rights.
  6. Click Save changes.
A pop up window informs you that the changes are saved successfully.
