You can edit an attached workflow.
Click Administration
in the toolbar.
Click Project setup.
Click on the applicable workflow
icon next to a folder in the content pane.
The Edit attached workflows window appears.
Adjust the applicable settings.
Click Confirm.
A pop up window informs you that the workflow is successfully edited.
