You can edit the file name, role, status and description of a workflow:
Click Workflows in the toolbar.
Select a workflow folder in the tool menu.
Select a workflow in the content pane.
- Click Edit.
The Edit window appears.
If applicable, edit the name, define the coordinator role, update the status, and enter a description.
Click Edit.
A pop up window informs you that the workflow is successfully edited.
