Export task statuses
You can export task statuses:
- Click Reports in the toolbar.
- Select the applicable option (Dashboard, By Role, By User or By Workflow) in the tool menu.
- Click Export to .xls.Note: The Export to .xls button from the Dashboard tab opens the Select a period window that allows you to export all tasks from a specified time period.
An Excel file including task statuses is saved to your download folder.
