Import a contact from an address book You can import an existing contact from another address book you have access to: Click Address Book in the toolbar. Click New. A context menu pops up. Select Import contact. The Import contact window appears. Enter the email address of the contact you want to import. The name of the contact appears. Select the contact. Click Import contact. A pop up window informs you that the contact is imported.
