Import an organization
You can import an existing organization from another project:
  1. Click Address Book in the toolbar.
  2. Click New.
    A context menu pops up.
  3. Select Import organization.
    The Import from project window appears.
  4. Select the project.
  5. Select the organization.
  6. Tick the Import organization members checkbox if you also want to import the contacts of the selected organization.
  7. Click Import.
A pop up window informs you that the organization is successfully imported.
If applicable, click Send notification in the pop up window to inform users by email.
