Import a role You can import a role from another project: Click Administration in the toolbar. Click Roles. Click Import role. The Import role window appears. Enter the name of an existing role in another project. The roles appear. Select the role you want to import. If applicable, enable Import members to import members with the role. Click Import. A pop up window informs you that the role is successfully imported. Note: Folder access rights are not copied while importing a role/member.
